need help with kinetik as main battery
tuff57
when i drive at night with my hids on parking lights dash lights etc on when the subs hit i get some dimming from my dash lights. my battery is new but isn't that strong so since my birthday is thursday i was going to give myself an upgrade my main starting battery to a kinetik 1400 i'm only running one audioque 1200 amp. is this the right thing to do? will it fix my dimming or is it a waste? and wheres the best place to get one of these?
Yes it is worth it. Will it ALONE fix your dimming...probably not 100% but it will def cut it down alot. Along with a new batt you should do the big 3 with 0 ga. and look into some good terminals.
I ran the stock charging system on my 1997 Civic with 750 watts RMS off of a single Kinetik and the big 2 of three (grounds only). When I upped it to 1,500 watts RMS, I had to charge the battery every now and again. Now I have a 170 amp high output alternator in addition to the Kinetik, the complete Big 3, and removed Honda's ELD circuit with a bootleg ECU! Now, I have no more problems!
lemme know ho upgrading to a single hc1400 works out for you on that amp
i have the same amp, and was looking to upgrade to the same exact batt but didnt wanna do it unless i knew it was gonna fix all my problems i already did big three with 1/0g wire, now just need to upgrade batt and i should be good
lemme know how it works for you //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
i think i'm going to do the big 2 ( the grounds) because the alternator wire is a pain in the *** to get to. it's an 85 monte carlo and i'm going to do the battery upgrade as soon as possible. how do i get the gm terminals onto the kinetik battery?
IMO try the "big 3" first...cheapest route and may very well fix the dimming. If not, battery next. If that doesn't do it, then go with a HO alternator. Sometimes the cheaper route will work! //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
i am going to try it, getting behind the alt is such a pain though, there isn't much room
big 3 fixed all my dimming issues in my girl's truck, i'd def try that out first...but if you just *have* the money, a new quality battery ALWAYS is a good investment, hands down.
That's what makes car audio so much fun! Hey, look at it this way, at least you don't have to tear into the dash or pop off door panels. //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
tuff57
tuff57
long island, ny
AlterEgo99
vegang
vegang
