Need Help with Install
McGruff
I have an old school Rockford Fosgate 800.4 that I want to install with 2 12" subs (DVC 4ohms), 2 6.5 mids (4ohms), and 2 4x6 plates (4ohms). I have no idea as to the best way to run them on my amp. Any helpful ideas would be great.
I do not think you can
I would suggest getting another amp to run the subs.
Those 2 - 4 ohm DVC's would present a 1 ohm load on that amp
or you could run the front speakers off the front 2 channels
run the subs in stereo (1 per rear channel at 2 ohms each)\
And run the rear speakers from the deck.
OP - you have a fine plan, this will work great on that amp. ignore the previous responses.
a pair of 4 ohm DVC subs can be wired for 4 ohm mono. wire them like that on Channels 3&4.
wire the other speakers in parallel for a 2 ohm stereo load. the amp is fine with that.
you will want some bass blockers on the 4x6 (around 300Hz).
---------- Post added at 08:47 PM ---------- Previous post was at 08:46 PM ----------
McGruff
McGruff
Florida
keep_hope_alive
vegang
vegang
