need help with install please. im desperate
broncolover81
ok heres the deal. I have a 94 honda accord. I just got done installing a kenwood KVT915DVD in the dash. it then goes back to a rockford fosgate 400.4 amp for the front and rear speakers and a kenwood excelon amp for the memphis 15" sub in the trunk. I installed the head unit in the dash and the brain box in the trunk along with the amps. I ran the wires and wired it all in. I hooked it all up and at first I heard a loud hissing from the driver passenger speaker. I checked the wiring and it ended up being a blown speaker. ok, I replaced the speaker and it all worked fine. now about a week or 2 later all of a sudden, the same speaker is making noise and all the other speakers cut out. now when I turn the deck off and then on again it will play like normal for a few hours till it cuts out again. I checked the wiring and it all seems to look good but I am not sure what to check. please please give me some advice on what to check on. the front speakers are kenwood 6 1/2" and i should mention that before this I had a different amp installed and the setup worked just fine with no problems. could it be a bad amplifier or wiring or what? PLEASE HELP ME BEFORE IT GOES INTO A SHOP.
thanks,
matt
broncolover81
broncolover81
arlington
broncolover81
BP1Fanatic
BP1Fanatic
