need help with digital designs recone
Lil Poot
you sturrin at me brah?
i'm getting my 9518 all cleaned up in preparation for the recone, and i'm having a hell of a time getting the last of the spider off. this is what i have right now, its wet with paint stripper gel ATM, will be the third time i've coated/scraped it with a wire brush.
i haven't gotten the recone kit yet, will it come with the 8 gauge also, or will i be reusing the wire thats in there now?
I use a chisel and a hammer to pry up the spider ring off of the basket. The spider itself is not glued down to the basket, the spider is glued to a plastic ring and THAT is glued down to the basket.
The recone will come with new 8 gauge.
I just did 2 HDC's and brake cleaner worked GREAT on loosening up the glue. Also a die grinder or Dremel with sanding discs to get it down to bare metal, plus a metal putty knife sharpened up to get the last of the glue off. SUCKS *** cleaning them up!!!
got it off, thanks. im also having a hard time getting the last of the glue off the top of the composite dustcap. does it even need to come off, or can i just put new glue over the top of it?
I lightly bend the edges when re using the CF dust caps. Just enough to let the ca flake up and be pealed off.
Lil Poot
Lil Poot
Wichita KS
Lil Poot
