Need help with decision of subs !!!!!!!
Depends on what you want. If you buy used. You can get better subs for he money , but there's always risk when buying used. If you buy new there are warranties in place So with that being said. I'd prolly go with 2. 12s and around 2000 rms as far as sq that's loud look at tantric md subs also look at ascendant chaos fi even ssa subs But like I said if you buy new. You will prolly need more $$$ to get subs box amp and wires. A break down for you would be $200 per sub $300 + for the amp. Then $175+ for a box if someone builds and ships it to you. And $60-$100 for wires. This puts you just about $1050 just to give you an idea
Thank you for the info helps alot !
first step to clean sounding bass is clean power, then the enclosure/install, then the quality of the sub. Spend more money on a proper install and box before you dump it on W7s or w/e pricey subs people gonna list out. If you do, you'll get stuck with a budget that can only afford a piece of ***** amp and a pre-fabricated enclosure and copper clad aluminum wiring....
i'd say keep your power around 600 rms a sub and do 2 12s in a properly designed enclosure with a quality amp that can be strapable if you plan on going even bigger later on when you have the money for it since with 2k rms and over, your going to have to spend money on a big battery bank, and a high output alt. keeping it under 1.5k you'll only need the big 3 upgrade and maybe a good agm battery under the hood.
This is very sound advice from someone who isn't trying to sell anything.
cagger8484
cagger8484
Michigan
cfox10
