Need help with box real quick. Got T/S specs and $$
528hz
Everything'sMiscellaneous
Ok...I need to get this figured out before tomorrow so I can build it, and I'll PP $5.30 if someone will help me with this.
I've tried to use winISD, but I can't input all the numbers because I don't know all the data yet (port displacement, and a few missing T/S numbers).
This is the deal:
I'm going to be running 2 of PSI's new 12s" in a 4-4.5 ft^3 box using one 6" aero port tunned to 30 hz (so I assume). I've got the T/S specs, but some of them are missing that winISD is asking for so....
I just need someone to plug these T/S specs in (if applicable) and tell me what would be the optimal size box and tuning for these subs.
Can anyone give me a quick hand? Here are the T/S specs:
Revc = 3.4974 ohms
Fms = 29.3385 Hz
Zmax = 38.5164 ohms
Qes = 0.5298
Qms = 5.3046
Qts = 0.4817
Le = 3.7342 mH (at 1 kHz)
Diam = 254.0000 mm ( 10.0000 in )
Sd =50670.7504 mm^2( 78.5398 in^2)
Vas = 54.1766 L ( 1.9132 ft^3)
BL = 15.5274 N/A
Mms = 198.1218 g
Cms = 148.5362 uM/N
Kms = 6732.3677 N/M
Rms = 6.8849 R mechanical
Efficiency = 0.2427 %
Sensitivity= 85.8678 dB @1W/1m
Sensitivity= 89.4613 dB @2.83Vrms/1m
The displacement of the 12" would be .17cuft
4 cubes w/ 1x6 inch port at 16.75 inches long = 30 hz good luck shared space no divider.
So are you saying "no divider"? This will be one chamber, yes.
But...my main concern is differences in tuning from 30-32 hz, and if that 4 cubes should be after or before sub & port displacement? That's why I would like someone to run the graph.
528hz
528hz
In the Space between Space in NM
Undadog
Mike Mccabe
