Need help with box for 2 cvr 12's
MarcusFranz
The vehicle is a 2003 ford focus sedan limitations are
16" tall
30" deep
40" wide
Kicker says taht each sub should be in
2.25 cu.ft. + port
Port 3 x 12-1/2 x 20-1/2”
this is really confusing to me because with those port dimensions and the re calc i keep getting rediculacly wide boxes that i cant fit help appreciated i plan on building 2 seperate boxes then bolting them together in the trunk that way i dont have to build it in the trunk (anything wider than 30" and taller than about 10" has to be built in trunk) thanks in advance
I loved the cvr i had in 2 cubes to 33hz. Kept up to my 12'' RE SE output wise on the same watts. I have not run the calcs but i bet kicker's spec is in the 38-40hz range but i would recommend tuning to 33hz.
Would be easy to do 4 cubes with two 4'' aeros.
Kevin
i got a box with 2 cvr 12 d2 in it ruff demitions are 22 deep 32 wide 16.5 high i think i get the exact messurements if you want them it averged about 135dbs and the box is built like shit so i think with a lil extra work it could sound really good. port would be a slot port 5 wide 15 tall with a 10inch back peace but then again them numbers might not be right
MarcusFranz
MarcusFranz
Cocoa, Fl
Theereus
