Need Help With Battery / Maybe Others
ctmaudi
Have two SA 10 D2s coming to run 1500rms @ .5ohm. Im looking for the least change possible cause Im already pushing the budget, and its a lease.
I was going to get this wire kit,
KnuKonceptz KCA 1/0 Gauge Power Amp Install Kit w/ Fuse - eBay (item 390232556987 end time Oct-29-10 08:40:01 PDT)
And some extra for Big 3.
Going in 2010 Nissan Rogue, the stock alt is 110amp (I believe). Ideally just a battery change and Big 3 would be best, cause I could easily undo it and I dont think it would void any terms of the warranty or lease. Not sure if a new alt would or not though, plus thats probably more money then I would have to spend anyway.
Any suggestions on what to get or look for? I have no idea what to look for in a battery.
If I have to Ill just run 1kw at 2ohm for a bit till I can afford better. Probably will anyway to break in the subs.
Had already got a quote from him for one. So I can just replace my main with that and should be ok? I really don't have room to run two.
Would a bat that size fit? I think stock is 24f.
Biggest battery I can fit is 10" long, 7" wide, 8.5" tall. Whats the cheapest single that can run what I need, or whats a small one (really small) I can put in the back? Also, my battery has a huge terminal going to it already, I dont see where to attach the two for the amp and Big 3.
View attachment 26520878View attachment 26520877
just run it in the back man, get a little extra 1/0g wire and make sure to fuse between 2nd bat and amp. gl
ctmaudi
ctmaudi
Akron, OH
rumple4skin
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
