Subwoofer cutting out
Sheasta
Ok. My sub is cutting out. I don't think it is my amplifier unless it doesnt have a protection mode light indication.
I have a 500 W alpine amp
Some 400 watt rms kenwood sub got for free replacing my Alpine Type R that went up in smoke (it worked for about two weeks before this I encountered this problem.)
"Pyle" of **** head ****
1F rockford fosgate cap
My sub doesnt make a sound on low volume. But If you put your hand on it you can feel that it is attempting to hit. If I turn the volume up the sub cuts out and the amp still has the blue power indication light on. So I assume it wasnt the amp. Only way I can get the sub to get power again is to turn the car off then back on. I rewired EVERYTHING. No luck. I dont have manual I got this amp from a friend I traded a 1000 watt kenwood amp for this 500w alpine so I dont know to much about the amp, except it has worked great for over a year now. It lasted the whole life of my type r and about a month with 2 P1's on 2 separate occasions. Like I said 2 weeks it worked with this kenwood sub before I encountered this problem. Ive had the car wired the same way for the whole year before I ran into this problem and started messing with all the connections. I wired it all myself. I ran out of ideas of what to do and I need help. I will try any recommendations you may have and let you know how it went. Thanks in advance.
what do you mean cutting out? it sounds like it doesn't work at all. explained how it is cutting out and what re wiring youv done please and what kind of head unit and rca cables do you have?
Sheasta
Sheasta
Boston, MA
rumple4skin
