Need help with batteries and alternator question
Xrojas13
Okay after months of research I think I will need kinectik 1400(maybe use as starting battery)
And kinectik hc2000 (in trunk) so far for alternator thinking about this powerbasterds hoa. But too pricey at 349 (product Id 7294-9-220-HD2-38)
Big 3 already done and also will be connecting both amps to battery in trunk
Picked up some supplies bernzomatic and soldering will be ordering some knu koncepts
0 gauge and terminals. Also did some research on relays but thinking maybe won't need it if I
Wire batteries in parallel. Setup is in signature will appreciate any inputs to see if this will work
Well basically my first install, beside regular amp kits. Just wanting make sure setup is going to work. Kinetik website kinda confused me about recommended batteries. Says input max rms wasnt sure if it meant regular rms or max watts
Its the exact same thing except you are adding the additional battery. Are you considering using isolators?
Do you guys reconmend 250 or 300 amp fuses for battery
You fuse for the Wire so if its 1/0 ofc fuse at 300 amps i would do 3 fuses 1 after 1st bat one before second batt and one after second batt before amp, thats just me tho. A FUSE IS NOT JUST A FUSE
Xrojas13
Xrojas13
Palmetto fl
mylows10
