2 Subs 1 Box 1 Terminal Wiring????
New too the site so sorry if this has already been answered. I have two 12" JL's in a open box running off a pioneer 760 watt 2 channel amp. The problem is I only have one terminal +\- hookup. Can both subs be wired too that terminal? Can I wire it for both subs meaning two sets of speaker wire to the terminals? Right now is set up 1 Chanel I'm guessing one set of speaker wire going to both the positive an negative. I haven't had subs since HS days so I'm not very savy in this area anymore. I can post pics tomorrow showing its current set up, I mean they hit hard but I have a feeling its only one of the 12"s. Thanks in advance
ID LIKE TO POWER BOTH SUBS IF POSSIBLE!!
-Mike
You'll wire the subs together using one of the following diagrams, then one set of wires to the terminal cup:
Or if they're single voice coil:
thanks for the quick reply's I bought them from a pawn shop so I'm unsure of the sub model I'm sure I could pull one of them tomorrow to give a more specific description of them but the look like 12w1v2 4 ohm max 600 watt peak 50-300 rms if that helps any. And I wanna say its a SVC. I need to know how to wire the 2 channel amp to the one sub terminal.
The reply above gives you a diagram for wiring them up.
BuickTooCold
BuickTooCold
Waterboro, ME
SoOfficialAudio
