Need Help With Amplifier
stefan.416
hey everyone i have a audiobahn 4002T 2 ch amplifier i just bought a pioneer TS-W257D4 10" sub because it was on sale. i was wondering wat would be the best way to set this up. the specs for the amp and sub are below:
AMPLIFIER
* Amplifier Class AB
* Number of Channels 2
* RMS Power (4 ohms) 100 watts x 2 channels
* RMS Power (2 ohms) 200 watts x 2 channels
* RMS Power (1 ohm) N/A
* Bridged RMS Power 400 watts x 1 channel
* Peak Power Output 800 watts x 1 channel
* Minimum Impedance Unbridged 2 ohms
* Minimum Impedance Bridged 4 ohms
* THD at Rated RMS Power 0.02%
* Speaker Level Inputs Yes
* Preamp Outputs Yes - 1 pair
* Built-in Crossover High-pass (HP), Low-pass (LP), Full (AP)
* High-Pass Crossover Frequency 50 - 750 Hz
* Low-Pass Crossover Frequency 50 - 120 Hz
* Subsonic Filter 20 - 50 Hz
* Signal-to-Noise Ratio 100 dB
* Channel Separation N/A
* Bass Boost On/Off Switch (0 or +18dB)
SUBWOOFER
Basket Material: Steel
Binding Posts: Integrated Single Sided Silver
Cone Material: Composite IMPP, Interlaced Aramid Fibre
Frequency Response: 18 - 600Hz
Impedance: Dual 4 Ohms
Magnet Weight: 74 Oz.
Mounting Depth; 5.63"
Power Handling Max: 1000 Watts
Power Handling Nominal: 350 Watts RMS
Sensitivity: 87dB
Surround Material: Fibre
Voice Coil Size 2"
Woofer Size 10"
each voice coil terminal is rated at 4 ohms
so can someone please tell me how i should be setting this up. thanks
ok thanks for the help. one more thing. how should i be setting up the voice coils. parallel or series. the sub has two 4 ohm VC. im not sure if the amp is 2 ohm stable in bridge mode.
AMPLIFIER
Read this
stefan.416
stefan.416
toronto
KidThump
