need help with amp....
prioracy
i pack da magnums
I have a orion 2500d running at .66 ohms with 3 memphis m3's, i thought it was the subs but i have taken them out and expected them and they are fine, here is my problem, i'll be listening to music and suddenly the bass will fade and won't be as loud, few seconds lata it will start bumping again, then it will fade, also no and then if i have it low volumes i'll hear a thump sound, kinda like a short burp.. Is it cuz the amp isn't getting enough juice, or is it a bad ground connection, currently i have a 0 gauge connected into a distro block, i was thinking of making 2 ground connections and ditching the distro block. If anyone knows what else could be wrong it would be greatly appreciated, also i have put in new rca cables......
-prioracy
bump..... running the amp at 1.33 ohms with 3 dual 2 ohm subs, still having the same probablem, it will hit hard sometimes and then the bass will lessen, and every now and then i hear a noise kinda like a test tone is playing, can anyone shed some light on my situation, can my amp be messed up?
prioracy
i pack da magnums
prioracy
chicago, IL
prioracy
