Need help with amp noise
Motofox
Hi all, I recently installed a JBL 4 channel amp in my car, and four JBL speakers as well. But when I turn the volume from 0 to 1, the amp noise can be heard. If I turn the volume up more than that, the amp noise level remains the same, but the music gets louder. Here is a schematic of how my audio system is set up, I followed the step by step advice at crutchfield also, so I'm not sure what exactly is causing the noise. Any insight would be greatly appreciated, and if you need pictures of anything, I have the interior of the car taken out so that would be no problem. Thanks!
can anyone tell me what might be wrong with this setup? am i supposed to have that loop triangle from the battery to the engine to the wheel well and back to the battery? Should the ground to the amp be in a better place?
Ok quick question first what type of headunit do you have? I was having a similar problem with a pioneer 5900dvd. A guy on here that is a installer help me out with this problem he has post on here: search " pioneer engine whine "!
Motofox
Motofox
Glendale Heights, IL
michaellane
Mike Mccabe
