adding another battery question..
grooverider
IL
I will be running 1200 rms in my civic. Im wondering what battery I can add, or replace it? Could I replace my front battery with a optima red top, and does it have enough power for that and 1200rms?
or should I add the redtop/yellowtop to the rear hatch?
Get a yellowtop under for under your hood, and if you still get headlights dimming, then you can buy the same size yellowtop for the trunk. By having 2 of the same size batts you won't need a solenoid/isolator (unless you want to play music with car off, then solenoid/isolator are a good idea)
But if you mix batts, then you need to isolate them.
Why, and how do you isolate them? What size yellowtop? and yellows are better than reds? because reds have more cca right?
It says d51R, but thats not a very good one for car audio is it?
Group Number: D51R (9073-167)
YellowTop®; Deep Cycle Battery; BOXED; Grp. D51R; Cold Crank Amp 450; Crank Amp 575; Res. Capacity 66; Amp Hour 38; Top Terminal; L-9 5/16 in.; W-5 1/16 in.; H-8 15/16 in.;
so with that high output 165 amp alternator, would I just need one optima to power my civic ,and my 1200w rms subs/amp?
here's my plan with my hatch, i have a 99. I am going to get a high output alternator from alterstart and a 51r yellowtop for under the hood and one for the trunk. i will be running 1/0 all the way back to/from both batteries and to the amps. I'm going to have 3000 watts.
so what should I do for just 1200 rms? Just get a high output alternator and 51r under the hood? I dont need 1/0 yet, I researched and 4ga just loses like 12 rms when you run 1200rms.
you think it would work?
and what about those ebay alts?
In the future I would like to maybe add another amp for the door/6x9's and then maybe another amp for subs, and upgrade to hdcs or something
or maybe ill fall in love with these sdc's and settle.
grooverider
grooverider
IL
thegreatestpenn
Mike Mccabe
