Need help with 2007 Dodge Ram Laramie
logikalone
Yeah I drive a Suzuki
So I just finished up an install on a 2007 Dodge Ram 1500 Laramie and have a problem. I installed a custom fiberglass enclosure under the passenger seat and mounted the amp under the drivers seat. The problem I am having is I tapped into a orange/white wire from the ECU that was 12 volt switched for the remote turn on. Well now the cars ESP BAS light and the traction control light remain on. even after unplugging the remote wire the lights still stay on. Can anyone help me? also is there another way to do a remote turn on wire with a factory headunit other then my normal way of finding a 12 volt switched wire or using hte acc. wire so this does not hapen again?
Yeah its one of those. I hate these newer dodge trucks, I just dont understand them. This is the third one Ive done and each one I ve had a problem with the way I do installs on every other car.
logikalone
logikalone
Pittsburgh,PA
logikalone
michigan born
    May 14, 2026
michigan born
    May 14, 2026
