Need Help Wiring
I have an XFL1244 and a VFL Hyrbrid 4480.1D mini and I want to wire to a 2 ohm load. ]
There are 2 negatives and 2 positive on the back of the amp and I have the sub wired up in my box. I went first negative to first positive and it sounds the best there but not at all like it should. What am I doing wrong? I adjusted my gain to about 5/8.
You have a dual voice coil (DVC) 4 ohm sub. You need to wire the voice coils in parallel to make 2 ohms. Don't worry about the extra terminals on the amp, they are connected together internally.
Connect one (-) on the amp to *both* (-) terminals on the sub. Connect one (+) terminal on the amp to *both* (+) terminals on the sub.
Like this:
Like this:
I did it exactly like that which is what confuses me.
I think he means on the amp. The first negative on the amp and the first positive. That's my guess.
Ah OK, I get it.
OP - looks like you have it wired correctly - what exactly doesn't sound right?
Things we can check next (in rough order of importance) are:
1) Set gains properly
2) Set crossovers on amp correctly (picture of switches and knobs would be great)
3) Set crossovers on head-unit correctly (tell us how you have it set up)
Final question: how is head unit connected to the amp?
bradch
bradch
Michigan
Jepalan
