Need help wiring (Two amps, two crossovers, two teeters, sub and 4 speakers)
AlecV
I have a question regarding how to go about wiring some stuff I have. First off, the install is including a xplod head unit CDX-F7710, two Rockford fosgate Crossovers, two T5002 amps, 1 T2 power sub, 4 Rockford speakers, , and I believe two Rockford tweeters. Could anyone give me any idea how the wiring would go? I've installed an amp and sub before, but wiring the speakers to an amp(or to the crossover and then to the amp?) is where I'm lost. I would appreciate some help with how the setup would look, even just a quick explanation like "HU>amp>sub or Speakers>crossover>amp" would help, I would like to know how an install would look with two crossovers, I can only find diagrams with one. Thanks!
(Oh, and could anyone say what these amps/crossovers/sub might sell for? That would be sweet as well)
Try typing "images for wiring amps/crossovers/sub/speakers" in your search engine.
Also your equipment should have come with instructions. If not, try contacting the manufacturer for wiring diagrams.
for amps to speakers : amp > crossover > woofer and tweeter
for sub: Amp > sub
you're head unit should really only be used for the RCA out and remote turn on. if you keep you're speaker wire going out from the head unit to your speaker it will defeat the purpose of using an amp to power them so make sure you disconnect them
AlecV
AlecV
De Witt, Iowa
Shorty Jenkans
