Need help wiring sub
ridefox734
i have a question on how to wire my boss amp to my boss subs. My amp is the RIOT 3400 Watts Monoblock Class D Power Amplifier and Im trying to hook it up to 2 Boss phantom P156DVC 2500 Watts 15" Dual 4-Ohm Voice Coil Subwoofers. how would i wire this since the amp has only a one channel out put? would i run 2 positive and 2 negative cables from the amp to the subs or would i run 1 positive cable from amp to sub then go negative to the other subs positive then from that negative to the amp again(bridge them)? Also my radio is a kenwood KDC-BT652U. Please help ASAP.
This is your problem per Boss Website which i doubt is true specially on 2.5VC they are saying 1250watts rms, anyways
your sub total power is 2500watts rms and you will be powering them with 1050, so each woofer will only get less than half recommended power
RMS Power @ 4 Ohms1050 Watts x 1
sub
RMS Power: 1250 Watts @ 4 Ohms
ridefox734
ridefox734
Gardner, MA
audiobaun
