Need help wiring my subs!!!!
i have it wired like that right now and every time i try turning up the gain it starts distorting. So i have my gain all the way down. i think the distortion might be clipping the subs?
i have a 0 guage wiring kit. but why would the cars electrical system matter? isn't it the amp that cant produce enough power to run both the subs?
amps dont magically run on nothing. you have to be able to feed them the amperage that they want. especially at a 1 ohm load where efficiency takes a good bit of a drop.
when you turn the gain up its causing the amp to draw more current. which your car cant supply. which causes the amp to clip and make the subs sound distorted, clipping will also cause the subs to overheat and die.
you need to do the big 3 in 1/0 and add at leas 1 group 31 battery in the back and a strong starting battery. there are a couple members on here that sell batts at a killer price just look thorough the classifieds section.
you may also need a high output alt depending on the size of the factory one.
alright i will look for a high oupur alternator. Do you know of any sites that sell high output alternators at killer prices? cause they can get pretty spendy.
I will switch out those wires and see what that does but isn't adding a secondary battery just more work for the alternator cause instead of one battery then it'll have two to charge?
Yeah that does make sense. But my bro has the same problem except he has 2 DVC 9500's and an audiopipe 15001d amp. and his diesel truck has two batterys and a pretty big alternator but its all stock. So thats why im questioning if thats the real cause for the distortion or clipping.
JM.MTX
JM.MTX
Salem, OR
Phoenix Risen
