NEED HELP whats happening??
yeah with the pioneer deck i have it allows me to look at the voltage as the system goes and it appears that the voltage drop makes the amp shut off to protect itself so yeah...what can i do about that? will an optima battery help or no? any other things maybe...let me know...
The voltmeter on the deck isnt really accurate.
Use a multimeter.
Hey, whats up. I'm the person who sold him the amp and subs. First of all the amp is mono, and well, it is a pretty big amp and pushes quite a bit of power. I'd wire it all up with 0/1 gauge and do the big 3 upgrade with 0/1 gauge as well. A optima shouldnt really be necessary with this setup, one of my friends has a similar one (runs at 850rms instead of the 900 on that one) and he just has all 0/1 gauge wiring and it hits hard and stays on. So just try upgrading your wiring, and lemme know if your having any other problems.
PS: a cap is really just a bandaid...really isnt going to do much.
i checked the grounds and they were good...i dont know what else...
wiring meaning bust out your dmm and check your voltage on your power wire.....try wiring your subs to a 4 ohm bridged mode to your amp.....if you can though cause I dont know what impedence you have on your subs.....and set your gains accordingly
NeroInferno
Rides Unlimited
NeroInferno
Bakersfield, CA
NeroInferno
