Need help w/ a receiver!!!
  • 2
That's a decent deck, but for the money I believe you can find better.
Preamp outputs are for connecting your headunit to processors, amps, eq's and such.
yes you could connect your subs to that headunit but I would strongly suggest an amp.
The difference between sub outputs and regular outputs is most sub outputs are non faded, and some even have a built in low pass crossover. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
657
721
957
Lewbrah485
Lewbrah485
Pittsburgh, PA
ramos
    May 16, 2024
    May 16, 2024
