Need help setting up Sentra!!!
Which Subs Should I Get (2x 12") for SPL with some SQ
  • Total voters
fieryhooligan
Hello all. New member but have been reading the forums for about a year now.
Here is my predicament.
I own a 2006 Nissan Sentra 1.8S Special Edition.
I currently have a low power amp driving 4 kicker KS600s, and the stock Nissan/Rockford Fosgate amp driving my subs (kinda dumb i know).
I am planning a HUGE overhaul, but trying not to break the bank.
Here is the setup as i see it
New mono amp
New Subs and Box
Keeping Kicker ks600s and kenwood amp for powering them
Caps or Batterys? not sure there
Big 3 Upgrade
Any suggestions? i have the new amp picked out, and while i would love help picking out subs and box, i am really looking for electrical help right now
Thanks EVERYBODY!!
The new mono amp I got is a power acoustic 2000/1. Any opinion as to whether I should use a cap or a battery. Please note that at this time I am not planning on upgrading my alternator.
I also drive a nissan sentra its a 2.5l but we have the same alternator and electrical i have done a partial big 3enough upgrade put a kinetik 1800in out front and kinetik 800in out back and have been using a 2k watt amp daily with no issues consistent 13.4v at the amplifier
Here's what you'll need.
-4 gauge amp kit or better(good gauge wire),I would recommend 0 gauge and then reduce it with a fuse near the amp/or a fuse block splitter if you want to run another amp in the future.
Your going to loose voltage but not much, if need 1 good battery under the hood.
666
732
961
fieryhooligan
fieryhooligan
Boston, MA
fieryhooligan
    May 18, 2024
    May 18, 2024
