Need help setting up Sentra!!!
Which Subs Should I Get (2x 12") for SPL with some SQ
  • Total voters
    6
Here's what you'll need.-4 gauge amp kit or better(good gauge wire),I would recommend 0 gauge and then reduce it with a fuse near the amp/or a fuse block splitter if you want to run another amp in the future.
Your going to loose voltage but not much, if need 1 good battery under the hood.
I am def gonna use 1/0 gauge wire, but why reduce it with another fuse?
2 reasons
1 reduce it with the fuse because the smaller wire pulls less less power than the larger 0 gauge ,
2the amp fits 4 gauge
fieryhooligan
fieryhooligan
Boston, MA
fieryhooligan
