need help picking an amp
kaceycowan
i think im going with 3 mtx 10"s
MTX RX103a Road Thunder 4 Ohm Triple 10” Inch 3 Sub Subwoofer Loaded Box Enclosure Woofer Speaker
* Brand New MTX Audio RX-103A 600W RMS 4 Ohm Road Thunder Triple 10" Sealed Enclosure
* 1200W Max Power Handling
* 600W RMS Power Handling
* 4 Ohm Operation
* Loaded w/3 10" Subwoofers
* Frequency Response: 49Hz - 150Hz
* Sensitivity: 90.5dB
* Aviation Grade Carpeting
* Sealed Design
* Dimensions: 35-1/4"(w) x 13-1/4"(h) x 5-3/4"(top depth) / 15-1/2"(bottom depth)
im not even sure what wattage on the amp to get.. or if a mono amp would work?
but i assume this would work
MTX TC6001 Thunder 1800 Watt 1ch Mono Block Sub Amp Class D TC-6001 Amplifier Subwoofer Digital
would that power 3 subs easily?
I have that exact amp that was used for about a week or so that I'd sell for $150 shipped but what are those subs final ohm load cause that amp puts out close to 700 rms but only at a 2 ohm load.
thanks for the offer.. but i am getting it for 150. um. would that amp power 3 subs? seeing that its rmx is 600 watts for 2 channel, 300 for 4.. what if its 3 subs?
If you're using three subs, just buy a mono amp. Or a nice 2 channel and bridge it. Final ohm load will depend on which subs you get.
-Bill-
You need to know what subs.. You're not going to want an amp that puts out 1000W x 1 @ 2-ohms if you have two DVC 4-ohm subs, now are you? Gotta figure out mang. ;-)
-Bill-
-Bill-
LMAO at your sig........Overexposure to what, awful gear?
kaceycowan
kaceycowan
murrieta, ca
dB-SPL
