blade micro 500 rms mono block? saw at the swap
Rsx_03
LoW aNd sLoW
looked like a solid build, nothing fancy just really small
i thnk the name was blade, it was black. i dont think it had a back, you cut out a template and bolt it on to your box or a wall. it was 500 rms mono block said about $180.
anyone seen what im talkin about?
dont think boss made it. isnt there blade series amps.
They are massive brand. Nice little amps. I have a couple bnib if interested I can certainly do better then the above stated price.
thanks for the reply ill probably buying off u shortly then. can you give me a link to them, like specs, manufacture w/e.
with the amps, can you cut a hole in your box and mount them in (internals sharing the same airspace as the sub)?
guy said they had 2ch amps also like it. im going to be needing 4x 125+ rms @ 4 ohms, i may have to get 2x 2ch amps depending on what they have.
Rsx_03
LoW aNd sLoW
Rsx_03
miami
tcguy85
