Hi all, I'm gonna get a 10" L5 which is 500watt RMS. Need help picking an amp for it as i have no background for amps at all. A brief explanation for amps would be greatly appreciated.
Lanzar Vive 231 Amplifier Specifications:
Electronic crossover network
Bass boost circuit
Bridgeable at 4 ohms
2 ohm stereo stable
Tri-mode capable
Gold RCA inputs
Line outs for left and right channels
200W x 2 RMS into 4 ohms
400W x 2 RMS into 4 ohms
1 x 800W MAX at 4 ohms bridged
2 x 350W at 2 ohms
Low pass filter controls
High pass filter controls
Subwoofer remote level control
Power and protection LED indicators
Advanced protection circuitry
S/N Ratio: 90db
Kenwood KAC-7252 Amplifier Specifications:
* 1000 Watt 2-Channel Bridgeable Amplifier
* Wired Bass Remote with Frequency Control Included
* RMS Power Rating:
o 170 watts x 2 chan. @ 4 ohms
o 250 watts x 2 chan. @ 2 ohms
o 500 watts x 1 chan. @ 4 ohms (Bridged)
* Power MOSFET Switching Power Supply
* Variable High-Pass Filter: 50 - 200 Hz
* Variable Low-Pass Filter: 50 - 200 Hz
* Adjustable Input Sensitivity: 200mV - 5V / 15W - 40W
* Line Output
* Gold Plated Power and Speaker Terminal
* High and Low-Lever Input
* Tri-Mode Operation
* Cooling Fan
* Red Illuminated Power Indicator
* Mono or Stereo Operation
* Dimensions: 15" L x 11-5/16" W x 2-3/8" H
These are the amps that i'm currently checking out. Just wondering whats mono or 2-4 channel amps. And why does one amp has many different watts?
Bass boost circuit
2 ohm stereo stable
Tri-mode capable
Gold RCA inputs
2 x 350W at 2 ohms
S/N Ratio: 90db
* RMS Power Rating:
* Line Output
* Cooling Fan
