nickle211
I have a Audiobahn A4002T 400Watt RMS AMP 2 channel
The specs are • 2 Ohms Stable Stereo
• 2 x 100 Watts RMS @ 4 Ohms Stereo
• 2 x 200 Watts RMS @ 2 Ohms Stereo
1x400 Watts RMS@ 4 ohm bridged
It says it is 800watts max
I want to get a 10" single sub to bridge.
What should I get? Should I run the amp at max wattage or rms
Should I get a dual 4ohm or single 4ohm SUB?
Can I get a 600watt sub that is dual 4ohm like a dub1000 audiobahn and only run it a 400 or will it send the whole 800max?
Please help
Also Should I hook up a crossover to save my amp the power it takes to run its built in crossover.I have one already.Just not sure if I need it hooked up.
Please help
