Frankensuby
I'm in Ur F0rumZ
I'm in the research aspect of buying the rest of my system. As stated in sig, I want an l5 10" 4 ohm....BUT....
The issue is as much as I love the Kicker line, there are other subs out there, and I don't want to have my eyes closed to other options, because I could then miss a better sub for my tastes.
The sub I will get will be a 10" of some nature, in 1" MDF sealed enclosure. I would like somewhere in the range from 400-500 RMS give or take 50 RMS. It also will be 4 ohm. My current thought choices are the Kicker L5, RF Punch P310D4, and Alpine Type-R.
My listening pleasure is a mix of all sorts of music, but my highest priority is a clear sound, with great quality. The sub will be a filler for the lower stuff (speakers are tuned for 63hz now) and also will cover those times where I feel like blasting my favorite Techno song or rap diddly. So I guess you guys would call me an SQ person.
I'm running into this: The L5 has a FR of 24-100 Hz, the Punch 20-200Hz, and the R 24-500 Hz. I'm aiming at hitting lowest possible for the 10", which would be the Punch, but at the same time I want something that is more of a punch of bass(hence sealed enclosure), rather than the long drawn out Fart bass that 12's easily can do.
So, which of these 3's has fastest hits, meaning they don't lag due to excursion, etc...Or if you have a better idea, what sub would you suggest with similar aspects.
P.S. - I'm leaning towards the Punch, as it has my ideal FR range and RMS, but I'm worried about lag. Should I worry?
