3 12L7s?
YZmoto125
I was looking at getting 3 0612L7s in my car to upgrade from my current 15L7. I am going to be selling off both amp and sub, but im not sure if I should get 2 DVC or 4 DVC subs, because i was hoping to power all of them with a zx2500.1. I dont have any of it yet but plan to buy it fairly soon, but should I get 2 or 4 DVC and how should I wire it?
2 dvc 4 ohm 15s is wat i would get with that amp to 1 ohm
The 15s wont fit where Im trying to put them. Ive lost a seat right now, but I can fit the 12s under the seats, and then im raising them 3 inches to get more airspace.
And since the kickers arent 1 ohm stable, so im taking it that it problably wont be able to do .67 ohms. Another option I was thinking about was going with was maybe a zx1500.1 and then two 2 dvc subs, so wire it all to 2 ohms, then a zx750.1, a 4 DVC sub and wire that down to 2 ohms as well. Is this a good option?
a ZX2500.1 wont handle a .67 daily but they can handle a 1ohm load tons of people including my self run them @ 1ohm.... i wouldnt put a L7 under a seat they need to be ported in a very big box in order for you to get the most out of them..
i am with you. IMO if your looking to go sealed look at a different driver. not that the l7 wont work sealed its just that you can get mroe output from a driver that is more suited for a sealed application
Ive head the 12L7s in a sealed box before, a very small sealed box, and it actually sounded really good and is very loud.
Do you have a wiring diagram for how to get 1.33ohms out of it?
Like this?
Also you guys say that the L7s wouldnt be as good, what other sub should I get. I really like kicker products a lot and love the L7s, and i didnt think the 2 12s sounded bad at all in a small sealed box and they were very loud.
Like this?
i did not mean anything bad about the L7. i run two 06 L7's myself along with three kicker amps. i was just saying thatsome subs have a ts that gears them for peak performance in a sealed box where as the TS for our subs although they come at to be good in both application most find that they are far better in large ported boxes
As much as I would like to have the space for a large ported box, I dont unless I were ty try to do a blowthrough from the bed of my truck.
How exactly did you wire the 3 amps to 2 subs? Also, is it possible to wire these 3 together with 2 kx1200.1s? Anybody have a wiring diagram for this?
or a single KX2500.1? Because you cant wire this to 1ohm either(according to kicker). Could I just wire this to 2.67 ohms?
Or should I just just wire this to 1.67 ohms as well.
Also is it safe to buy off of ebay? They have a lot of those KX2500.1s for cheap there that claim to be new in box.
three amps yes but not all to the subs.
i have one 1500.1 running to each sub and 350.4 running to the front stage.
YZmoto125
YZmoto125
Minnesota
stuckinok
