Need help! on what amp i should buy
Fallen773
I need some help on picking the best amp. What i dont understand is how the ohms work with each channel. And help would be awesome
I have a set of JBL GTO608C 6.5-Inch 2-Way Component
Rms:70 watts/ Peak:210 watts/ 2ohms (front)
The rear set of Kicker 41KSC674 6-3/4" 2-Way Coaxial Speaker. Rms:100watts/ Peak:200watts/ 4 ohm
Head unit is a Kenwood DPX301U
Whats your maximum budget?How much space do you have for the amp/willing to give up?Im running the same HU in my work truck on 2 sets of Hertz Coax/6.5s, and a pair of Polk DB6.5s for each door on an old JBL GTQ400,Dayton 10ho on an old school Mean Machine 66hc@2ohms
Money is not a problem. But i really dont want to spend more than 150$ but if needed i will. As for space it will most likely go under my seat. Space a bit limited. I drive a 2002 tundra access cab. I know i need a four channel amp. But idk on if my rear 4 ohm speakers can run on a 2 ohm channel or vice versa
Fallen773
Fallen773
San dimas, CA
audiobaun
