Need help on RL-p box
gixxer9
I am looking to design a box that will net 1.5 ft^3, and be tuned at 34 hz that will still fit under the rear seat of my Silverado.
I have come up with some rudimentary dimensions that will provide an estimated 1.68 ft^3 gross, and 1.53 ft^3 after sub, but before port.
The RL-p 12" displaces .15 ft^3
From the top: W=15", L=32"
From the front, from left to right: H1=7", H2=9", L1=12", L2=20"
You should be able to interpolate the rest...
Thank you!
The internal volume should actually be greater than 1.68 ft^3 because I just calculated volume by breaking my box into two, without compensating for the lack of the two adjoining sides...
Mr. Cabinetry, I sure could use some advice from you.... I will probably even ask you for a quote on building the final design via pm.
Thanks.
If you're willing to take a 2 hour drive I can build one for you. But I'd do the RL-P no higher than 32Hz as they don't like/need tunes that high and lose SQ pretty quickly.
I'm assuming the sub will be in the part on the right in your picture. That's the 20" length part, correct?
That's correct. I appreciate your help on this, as I have never gone ported before. I want to make sure that my SQ is as good as possible.
Well, 34 hz is what Soundsplinter recommends for the small ported box... I have some pretty extreme size limitations to follow here, and 1.5 ft^3 net is about the most I can do.
how much power you got? if its anywhere near 1000 rms go sealed for simplicity. my 12" x 2 rlps would bounce the wipers sealed....in a mini van //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
With ~500 rms each? What size box did you use? I have a limited amount of space to work with... I might be able to come up with about 2 ft^3 gross...
I have three monoblocks in my possession, an Orion 1200d, an Audison lRX1.400, and a Zapco 1100.1, all of which are around a 1000 watts rms...
gixxer9
gixxer9
Madison, WI
gixxer9
