need help on double din install on 06 Chevy Equinox LT
  • 5
just wire the camera to an acc source. there is a button on the pioneers that will show you what the camera is seeing even if the reverse wire on the deck isnt powered up. You just have to make sure the camera has power.
I wired it in but had to move the vedio cable to the input in. I may wire it in to the reverse switch to make it easier on my wife. And add the switch for when i tow. Thanks for the help
I rewired it like i had in my drawing. The camera comes on in reverse and when i flip the switch. I had to solder in a 1N4001 diode to keep the reverse lights from coming on when i turn the switch on. Thanks for the help. Next install will be a single 8" sub to help with the bass. Not looking for anything overpowering. The stick speakers cant handle the bass very well.
I would tend to blame the amp more than tbe sub if all wiring checks out. Skar is known to be on the finicky side when abused (not enough power...
139
718
760
978
Andrewme
Andrewme
Minot, nd
Andrewme
audiobaun
    May 19, 2024
    May 19, 2024
