Need help on best installation setup
mikem6977
Ok I am a dad trying to get the best sound out of what my son is getting for Christmas. So that being said please spell out your reply so an idiot like me can understand please. It is all going in a 1997 camaro. I have a kdcx396 going in, I have 4 new alpine sps-610's going in, and for subs I have 2kfc-xw12's going in a box designed for the car, and for an amp, I have a KFC-7201. I know the amp is a little older but kinda ran out of money at the end. So I ask you, what is the best way to run this system?
run all the speakers off the deck ,and the subs off the amp if you can .not sure if the subs and amp are compatible can you show me the amp and sub specs? also you'll need an amp kit.
Here is the specs on the subs,
Specifications
Nominal Impedance 4 Ω
DC Resistance 3.6 Ω
Voice Coil Inductance (mH) 1.5
Piston Area (Sd) 0.051
Force Factor (Bl) 10.2
Volume Acoustic Compliance (Vas) 78.7 liters (2.779 cu. ft.)
Moving Mass (Mms) 184.0 g
Resonance Frequency (Fs) 25 Hz
Mechanical Q Factor (Qms) 6.800
Electrical Q Factor (Qes) 1.050
Total Q Factor (Qts) 0.900
Maximum Peak Power 1,200 W
Peak Excursion (Xmax) 15.1 mm
Displacement 2,155 cc (0.072 cu. ft.)
Mounting Depth 153 mm (6 in)
Weight of Magnet 1,780 g
Voice Coil Diameter 65 mm
Here is the specs on the amp,
Audio Section
Max Power Output ............................................................................................................800 W × 1 Rated Power Output
Normal (4 Ω) (20 Hz – 20 kHz, 0.08 % THD) ....................................................................150 W × 2 Normal (4 Ω) (DIN : 45324 , +B = 14.4V) ........................................................................150 W × 2 Normal (2 Ω) (1 kHz, 0.8 % THD) ....................................................................................230 W × 2 Bridged (4 Ω) (1 kHz, 0.8 % THD) ....................................................................................460 W × 1
Frequency Response (+0, –3 dB) ..................................................................................5 Hz – 50 kHz Sensitivity (rated output) (MAX.) ................................................................................................0.2 V Sensitivity (rated output) (MIN.) ................................................................................................5.0 V Signal to Noise Ratio................................................................................................................100 dB Input Impedance........................................................................................................................10 kΩ Low Pass Filter Frequency (18 dB/oct.) ............................................................50 – 200 Hz (variable) High Pass Filter Frequency (12 dB/oct.) ..................................................................................150 Hz Bass Boost Circuit (90 Hz) KAC-7251 ............................................................OFF / +6 / +9 / +12 dB Bass Boost Circuit (90 Hz) KAC-7201 ............................................................................OFF / +12 dB
General
Operating Voltage ..................................................................................14.4 V (11 – 16 V allowable) Current Consumption (4 Ω, 10 % THD) ......................................................................................43 A Dimensions (W × H × D) ......................................................................................285 × 57 × 305 mm
So I can't bridge the subs and get 230 watts to them a piece ?
issue is the subs together will give an impedance of 2 ohms bridged and the amp will not do that ,it will only do 4 ohms bridged .you'll blow up the amp.you need either 2 subs that are single 2 or 8 ohm or an amp that does 2 ohms mono
Prolly in the 200 -250 range. But I will probably set it up like I mentioned for now until I can catch up with Christmas and all.
mikem6977
mikem6977
Nixa
mylows10
