Need Help On AMP
It depends. Can the amp handle the load. If so fire away. Just get you some earplugs //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Originally posted by Wheeler I have one JL 12W7 and I am gone to Push It With a Kicker 1200.1. Should I Bridge the Amp to get More Power to the Sub
trying to make a half channel amp huh? lol cant bridge a 1 channel but you can run it into lower impedance
11
657
While we're speculating, why not bump up your volume gain (no pun intended) for just a few dollars more (literally) and go with the 8" versions of...
5
962
* The fuse at the start of the cable needs to be equal to or greater than the fuse/load at the end of the run. * The cable needs to be capable of...
4
No not in this situation.PM sent for proper use of the Y splitters for this situation
34
5K
Wheeler
Wheeler
Philadelphia
audiolife
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
