Need help on amp selection !!
For 1600w rms, I'd go for a saz 2000. Its good to have the extra power, especially if you need better efficiency.
You might be better off getting two SAE1200's or AQ1200's
That way you can pair the subs together for a 1 ohm load. Because getting 2000w @ 2ohms is a bit expensive...
For 1600w rms, I'd go for a saz 2000. Its good to have the extra power, especially if you need better efficiency.You might be better off getting two SAE1200's or AQ1200's
good thing you edited your post, i was just about to yell at you, he has 4 cvrs'
Good deal I just ordered the Hifonics BXi 1610D sounds like I'm going to be very happy with it. Thanks for all your help.//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
as much as i like the brutus amps it will not work at all dude and you got ***** on that amp if you bought the 1 in the link posted above. 200 for a refurb is a ripoff i sell them new with factory warranty for 250 shipped. it will only give you 1100 rms watts at 2 ohms so you are gonna get 275 rms per sub thats all. for 325 i coulda put you into a monster 2kw mbquart amp with 2 yr warranty lolz
Tech. I haven't paid for anything and no it wasn't the one above I found one brand new for $250. as well with warrenty but if it won't work then I don't want it. What do you have in mind.
bizkit11
bizkit11
Cocoa, Fl.
Hawkins97
michigan born
    May 14, 2026
michigan born
    May 14, 2026
