Need help making the power wire fit.
trim it to fit, buy a reducer, or buy a distro...
I like trimming, as it was the only option I just listed that didn't include the word buy //content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif
It would be more than a little //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
x2 that's what it did for both my amps.
Where did you buy distribution block from? I really want to buy my amp install kit today but I need to no how big fuse I need to buy can anybody help me on that .
thanks,
Blake
Add up the fuses on your amp. Ie if 1 fuse has fuses totaling 70 and another 35, then you get the closest for each, so in 1 chamber youd have anywhere from 65-80 and in the other 25-45. The one at the front should be the total, so if you use a 60 and a 40 then you should have 100. You can go abit higher or lower.
If you have lower, than it will just blow the fuse, if you have higher, than the fuses at the amps will blow.
that or just trim a little off the wire.
WRONG!!!
just run the 0 gauge to a distribution block, than 4 gauge off that to the amp
CORRECT!
lol i like the trimming part... do that...
NO don't do that!
DO NOT TRIM IT. buy a reducer or a disto block..
****in ghetto afro enginer's
WRONG!!!
CORRECT!
NO don't do that!
there is nothing wrong with trimming it...it is free and easy...it doesn't have to look like a freaking masterpiece to work
hitman34608
hitman34608
Knoxville,TN
SPLEclipse
Mike Mccabe
