need help installing motion Sensor PLZ!!
JCivicHb
ok just got my new alarm in the mail, gonna install it soon, but the motion sensor just came in a box with no instructions- i know the positive and the ground, but there are green and blue wires that say exterior and interior - where do i hook these up to on the brain? thanks
ok the wires available are-
- lock output
-unlock output
+12v
parking light output + 7a
siren output+
passenger unlock output - 500ma
auxilary 2 output -
armed output - 500ma
horn output -500ma
dome light output - 500ma
hood/trunk input -
auxilary 1 output - 500 ma
ignition +12v
ground
door trigger input+
door trigger input -
which of those wires should i hook up the motion sensor too? thanks
ive never installed an alarm but i know pretty much the basics. Its just this add on adn the glass break sensor i dont know where to hook up. thanks
well i didnt ask for opinions- but anyway i paid less than one hundred dollars for this alarm. It is one layer of security out of many that i have- all i wanted was an alarm that will possibly wake me up when someone is ****ing with my car- which this will do. Anyway- i have read on several different forums in my search for knowledge on this subject- that that is exactly what you ARENT supposed to do. anyone else have an idea?? thanks
the shock sensor on most alarms have a constant power. (red) a ground (black) a triger (most likely blue) and a warn away (green)
thats what you would tap in too, also dioed isolating the two sensors from eachother.
the shock sensor wires are red black blue and white
the motion sensor wires are black green blue and red
thx for your help btw
ok, so would i tap a glass break sensor into these as well?? or more than likely just the blue wire- since it only has blue black red.... thanks a lot
correct. but im not to famillar with asian wolf alarms. the best thing to do is to test teh wires. first.
but the way i told you to hook the wires up by diode isolating the sensors from eachother, is the way to go.
JCivicHb
JCivicHb
Denver
atoz350
