Need Help installing in-dash monitor
I did my own install on my Alpine D300 after only installing a few simple cd players. It is basically the same thing, just that the wires have to be run to the brain in a hideaway location, usuall under the driver or passenger seat. It takes alot more time with seat removal and running all the wires, but is actually a simple job. Good luck
Thanks I didnt know that. Also i heard if just connect the parking brake wire to the ground wire it will override the video from not playing. Is that true? If not does anyone know how?
hey clinton, i'm having the same problem with my vm9111ts, Please let me know if that parking to ground method worked. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
i believe that model (mines on the way!!) requires a sequence. You have to hook that wire to a toggle switch then ground the toggle switch. There's a certain sequence you have to do in order to get it to play while driving.
Its just like connecting a regular radio. There is no hideaway box for that unit. The only thing that you'll want to do different is connect the reverse wire for a back-up camera. If you don't have one you don't have to worry about it though.
As for the by-pass, look up the Alpine by-pass on Ebay. (PAC-TR7) It works similarly. Its a relay to automatically by-pass the unit.
Actally the JENSEN (not Alpine:read:) VM9311TS does have a hideaway unit for video out, XM hookup, and jlink cable for iPod.//content.invisioncic.com/y282845/emoticons/banghead.gif.8606515f668c74f6de0281deb475b6fd.gif
http://media.mainstreetcommerce.com/3.9/media/item_image_sheet.aspx?domain=audiosavings.com&item_guid=21e25f39-cd62-43f6-9be4-ceb6c8c23a5c&image_guid=c5534053-448f-4252-b6dc-7763f26ff2e6
clintonwrght
clintonwrght
Dublin, OH
99 3.2 TL MBP
slater
    Oct 4, 2025
1aespinoza
    Oct 4, 2025
