Need help !! I have a pioneer GM-D8601 Amp
Brian M
CarAudio.com Newbie
So I have the above mentioned amp and 15” sub box with a blown diamond sub. Looking to replace the blown sub. The amp does 800 watts at 0 ohms. Anyone know of a good speaker I can use with this amp. Don’t want to spend more then 300. Thanks in advance.
Think this amp does 500 watts at 2 ohms. The speaker mentioned above is 600 watt at 2 ohms will I have a heat issue and burn up the sub ?
Not if your gain is set correctly. But 9/10 people will try to push the amp more to get more power since the subwoofer is so underpowered and end up clipping it to death.
But that subwoofer is a Dual 2 ohm which will wire to a 1 ohm load.
Brian M
CarAudio.com Newbie
Brian M
Florida
BCotrell
Mike Mccabe
