need help for finishing installation
Lebowski_951
I'm installing a pioneer avh-p4000 double DIN unit in my 2006 Ford Ranger and I'm running into a few problems around the end of the installation, i'm really hoping you guys can help.
So far I've connected my illumination, constant 12v power supply, and all of my speakers.
Now is where I'm having trouble. My ignition (accessory wire?) on my new pioneer unit meets with two identical black/pink wires from my ranger. is one positive/one negative? if so do i run my negative to ground?
Also, in order to ground should i run my ground wires from my pioneer head unit through the harness, or right to the chassis?
I've only got a basic multimeter as far as tools go, i figured i installed my last cd player why not try this? and i do not have a wiring harness i'm matching ford factory wiring charts with the pioneer wiring charts and I've been splicing them together, thanks for the quick replies BTW
Lebowski_951
Lebowski_951
canada
Lebowski_951
NorthFramingham
    Jun 30, 2026
