IgnoreMe
CarAudio.com VIP
Originally Posted by JmacMeh, calculators **** ... Use a sheet of paper and a pen, draw out your enclosure, make sure it's right ...
Here's a step-by-step process of how I do it ...
1) Measure your trunk for max dimensions and note TWO dimensions that would be preferable. Subtract twice the thickness of the desired dimensions to get the desired internal dimensions (i.e. 3/4" MDF, 20" height = 18.5")
2) Figure out desired net volume, tuning frequency, and port area.
3) Figure out port length using the following formula :
Lv = Av*1.84*10^8/[Vb*1728*(Fb/0.159)^2] - 0.823*sqrt(Av)
Lv = Port Length in inches
Av = Port Area in square inches
Vb = Net Internal Volume in cubic feet
Fb = Desired Tuning Frequency
4) Draw out a diagram of your enclosure on a sheet of paper and figure out the displacement of the port.
5) Add up all displacements (port, driver, brace)
6) Add displacements to desired net volume and multiply by 1728
7) Divide by the two desired interal dimensions to get the third internal dimension
8) Add twice the thickness of the wood to get the exterior dimensions
im having trouble with step 2. desired net volume: 2.4 ft^3. easy. desired tuning frequency: 29 hz. easy. desired port area? what is that. is that just how big i want the port to be? i thought that depended on the frequency? this is my first time tryin to design a ported enclosure so bare with me.
if i cant figure this thing out i already have ported box plans for a mag but only problem is if i build it with those specs it will be above window line in my explorer so im tryin to adjust it by makin the height smaller while still keeping the same tuning frequency, and same volume.
