Subless
Hi, first post.
I have a Jeep JK Unlimited with little space for a subwoofer unless I want to
use up cargo space and I really don't. There is a sub build by JL that is a custom fit over the
wheel wells. - JL Audio Stealthbox® (Black, Driver's Side) Custom-fit fiberglass enclosure with one 10TW1v3-4 subwoofer — fits 2007-up Jeep Wrangler Unlimited at Crutchfield.com
$600 - I don't want to spend that much. I'd like to build a round enclosure maybe sonotube that would fit in the same area.
JL makes a shallow driver -
http://www.amazon.com/10TW1-4-Audio-300W-4-Ohm-Subwoofer/dp/B00OALB31A/ref=sr_1_1?ie=UTF8&qid=1460588614&sr=8-1&keywords=10TW1-4 which is SVC 300w RMS @4ohms
The amp I'm looking at puts out 340w rms @4ohms and 600w @2 ohms
so I thought I'd build two of these and wire in parallel for final 2 ohm impedance and each driver getting 300 watts each @2ohms. Sound right?
They show a rectangular sealed design for this driver - 16.125 in x 14 x 5.25 deep. Can I make a round enclosure for it that would work ? I'm not quite sure yet how I'd mount it, but a 12" wide tube I'm thinking could fit this 10" driver. I'm concerned that if I'm supposed to match the volume of the rectangle above, then this tube might end up being too deep. I didn't really want to go more than about 8".
Thanks to any guru's who might have a clue on this one.
Thoughts?
Thoughts?
