Need help deciding on system
That sub will not work with that amp, it has dual 2 ohm voice coils which would give you a final impedance load of 1 ohm, too low for that amp. If you tried to play it on that amp the amp will cut out and go into protect mode, or possibly even blow. A type-R would work well with that amp although you would need the model with dual 4 ohm voice coils.
I would get the dual 4 ohm type r and wire it to 2 ohms, giving it 500 watts.
nice equipment choice btw, what kind of box you gonna use?
oh i see thanks for the help guys.
but I'm not sure on the box yet, what do you guys recommend?
i have the same setup...it pounds. I have it in an suv and the stuff in my cupholders shake around...my rear view shakes like crazy...my roof flexes...etc. I have a single 12" 4ohm type-r wired at 2ohms to the alpine mrp-m500 amp. I built a custom ported box that is 2.15 cubic feet after displacements tuned to 37hz fb. (the manual reccommends 36 hz fb/33hz f3 but i listen to rap/hip hop so i tuned alittle higher)
reaver18
reaver18
Phoenix, AZ
BumpinTypeR
