Need Help choosing temp AMP
momax_powers
Im looking for a temporary budget amp than will do 1000@2 and 1500@1 unclipped..budget is 200shipped (im in Toronto Canada). Need some input as im currently looking into these and will be pulling the trigger in the next 24hrs
1)Audiopipe APSM-2000
1 x 900 WATTS RMS @ 4 OHMS
1 X 1400 WATTS RMS @ 2 OHMS
1 X 2000 WATTS RMS @ 1 OHM
can probably get a clean 1500 out of it
2)MB Quart ONX1.1600
550 Watt x 1 Channel @ 4 Ohm
1100 Watt x 1 Channel @ 2 Ohm
1600 Watt x 1 Channel @ 1 Ohm
most say these will do rated if not a little more
3)Hifonics ZRX1500.1D
4 ohms: 500 watts x 1 chan.
2 ohms: 1000 watts x 1 chan.
1 ohm: 1500 watts x 1 chan.
pretty much the same as the MB Quart from what I see
lemme know guys...also consider used amps from members
Forget 1 and 3. Avoid Audiopipe if you want clean power, and same goes for Hifonics other than the BRZ series and a few of their older amps
Think of it this way.. Why would Hifonics make an amp with a similar rating to the BRZ for a cheaper price? Because the quality reflects the price
I love my apsm 2000 kicks the sht outta my sa15's. absolutely no problems. I have no "audible" clipping at 2 ohms and recommend it highly for a temp amp it's perfect just be reasonable with your gains .
I have run into several people with the apsm2000 and all of them are happy with the value. Everybody that downs them do so without ever owning one . They are budget amps you do get what you pay for so don't expect the world out of them and u will be atleast satisfied with the value.
Btw mine benched 1139 watts at 2 ohm with no clip at 11.8v Not enough power supply for my guy to bench it at one ohm ,for 175 shipped its a pretty good bang for the buck..
The sq1200.1 is a good value as well might check them out. That's what I was gonna get till my buddy got in a bind andd sold the ap to me for 75$ bnib
yea i figured since the apsm1500 does around 1100 clean at 1ohm, the apsm2000 would do about 1500
-im torn between the mb quart and the audiopipe
yea i figured since the apsm1500 does around 1100 clean at 1ohm, the apsm2000 would do about 1500-im torn between the mb quart and the audiopipe
I'd go with the MB Quart. The AP may have less distortion when not running full power but the distortion is still there. The fans are also loud and annoying.
are there any threads on the onyx 1600..clamped..i cant seem to find any
momax_powers
momax_powers
Canada
naughtyca
