need help choosing amp
Specs
Sensitivity: 91 dB
RMS Power Range : 500 Watts
Impedance: 4 Ohm
Low Frequency response: 25 Hz
High Frequency Response: 250 Hz
Diameter: 12 Inch
Radial vented steel basket
2.5" voice coil
Cmax Optimized Spider
Double Stacked Magnet
Power Range (W RMS):500
Impedance (ohms): Dual 4
Sensitivity (dB SPL): 91 (2.83-V input @ 1 meter)
Freq. Resp: 25Hz-250Hz(±3dB)
Diameter: 12"
Depth:5.4"
ok 1 last question. would i only need this one amp to power both subs and is there any other amps i can get or is there any place i can go to find out how to find a amp. ok yea thats more then 1 question.
Yes the one amp would be what you need to power both subs. Yes there are tons of different amps out there to power your subs. For starters here is a good place to browse arround. You by no means restrained to one company.
ok last question haha sorry um ok would i need a 2 channel or mono amp and also since each sub is 500 watts each would i need a 1000+ watt amp
like which of these would i need
1 x 1000 @ 4 omhs or something differnt
2 x 500 @ 2 ohms
? x ? @ ? ohms
1 x 1000 @ 4 omhs
2 x 500 @ 2 ohms
1 x 500 @ 1 ohm
all those should work. It does not have to be a mono. Anymore most mono's are class D's which by their circuitry have much better results for sub applications.
hey i found a amp and was wondering if it would work wit my subs. here are the specs for it
Number Of Channels: 2
Maximum Power: 1000 Watts
2 x 250W @ 4 Ohms.
2 x 500W @ 2 Ohms.
1 x 1000W @ 4 Ohms.
Blackmaxx High Dissipation Heat Sink distributes heat evenly and effectively.
Blackmaxx Design is just right for the tuner.
Illuminated Blackmaxx M on top plate.
Crunch MOSFETS for clean, high speed, high performance output and Crunch reliability.
G-Force Power Supply - PWM power supply delivers reliable current on demand.
SEPP Single Ended Push Pull A/B Amplifier Operation.
Separate Bass and Treble Controls.
Bass Boost.
Versa Cross featuring HP and LP Adjustments.
High Level Inputs.
Silver RCA Inputs.
Silver RCA Outputs.
Protection Circuitry - ensures your amplifier will not be damaged by current, short circuit or thermal issues.
Green "On" LED
Red "Protect" LED
ok ive been going through a lot of amps n just cant find what im looking for. in the last post someone recomended a amp but that wattz didnt meet up to the 1000 i would need for the 2 subs. so can someone tell me wat kinda amp i should be looking for. Im wondering do i need
1 x 1000 @ 4 ohms or what
which would be the best one for the cheapest price. if someone could jus give me the setting i would need i can look up the amps.
you can also get a 1 ohm mono amp...
these are your wiring options: the first and second ones.....you would be better off gettin a 1 ohm amp such as the hifonics bx1000 or the bx1500....look at ikesound.com
http://www.jlaudio.com/tutorials/wiring/index.html
although im a little confused....are they dvc 4 ohms or svc 4 ohms..cause in 1 of your posts it states impedense=4 ohms
then in the same one it said dvc 4 ohms
ritzthekracker
ritzthekracker
Salinas, CA
Sleeklsc
michigan born
    May 14, 2026
michigan born
    May 14, 2026
