Viper or Memphis?
Devin_9_2004
Hey guys,
I'm going to be running a single 15xxx ported along with a set of re comps and vifa midbasses. I'm wondering which set of amps I should go with. I'm looking at the new memphis 16-mc1500d and the 16-mc3004 or the viper 2500.1 and 500.4. I'm having a tough time deciding what to do. Get a XXX built with dual 4 ohm coils and run the memphis amps, Get the same dual 4 XXX and run 2500 watts to the XXX with the 500.4, or get a dual 2 ohm XXX with a viper 2500.1 at 4 ohms and save the extra power for another setup later on.
I will get more power from the viper, but I like the small design of the memphis and I hear the memphis amps have amazing sound quality. On the other hand, it would be nice to have 2500watts available. Is it even safe to run 2500 to a single 15 XXX?
Decisions Decisions //content.invisioncic.com/y282845/emoticons/crying.gif.ec0ebefe590df0251476573bc49e46d8.gif Help!
Thanks,
Devin
I personally like the Viper 2500.1, and yes you can run 2500 watts to a 15 XXX, just be careful with the gains. The room to expand is also a big bonus, and if you run a more powerful amp, they should last longer because you dont have the crank the hell out of it in order to power the sub enough.
no u cant, the viper is stable at 2 ohms. go with the memphis amplifiers.
he originally said in his first post he was gonna get a dual 4 ohm so he could run the viper to it. also consider a crossfire vr2000D. excellent amp. very efficient, makes rated power at 12.5 volts and does about 20% more at higher volts. very clean and powerfull amp.
I can also get an awesome deal on the directed amps. A 2400d and a 4500, or the memphis amps are my choice now. The vipers are now out of the picture. The orions are too much money for the slight difference between the viper and dei.
devin, I am trying to see about the ORion now
Devin_9_2004
Devin_9_2004
Michigan
Devin_9_2004
michigan born
    May 14, 2026
michigan born
    May 14, 2026
