NEED HELP choosing amp
jgibson34
10
PA
i need to find a powerful amp to power my system (not an expert)
Rear Deck speakers- Infinity 5-1/4" 2-Way Car Speakers with Plus One Cones (Pair) Handles up to 135 watts peak power (45 watts RMS)
H.U - JVC 50W x 4 MOSFET 50 watts peak (20 watts RMS) x 4 channels 2 pairs of preamp outputs (front and rear/ sub switchable)
Subs - Alpine 12" Dual-Voice-Coil 4-Ohm Subwoofer Handles up to 1500W peak power (500W RMS)
Sub box - Q-Logic 12" Dual-Chamber Sealed Subwoofer Enclosure
with a Dual 4 sub,you may not get a 2 channel amp that does 2 ohm mono, and a 4 channel amp for the whole system might also be out of it, as they will only do 4 ohm bridged.
If you're looking into a single amp, u should try a 5channel amp,
Look into the Kicker KX700.5, add a pair of speakers up front and that should be good.
im also going to add two speakers to the front doors as well i should stick with a 5-channel ampto power all of this?
Not likely.
Unless you're wanting to come off a fair bit of coin you'll likely not find a suitable 5-channel amp that has enough wattage from the sub channel to do your sub any justice.
If you're going to add speakers to the front then you'll either want a 4-channel to amp the front and rear interior speakers or just get a solid 2-channel to amp the fronts and then drive your rears off of the headunit then get a separate amp for the sub.
Everything i listed previsously brought me to around 700 including front speakers that i picked out so probably close to a grand
jgibson34
jgibson34
PA
jgibson34
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
