need help car stereo wont turn on
there is your problem. It shorted out I have done the same thing. I luckily had crutchfield support id the exact fuses to check. Its a fuse you just are looking in the wrong place. my car had 3 different fuses that could short out and it only blew one that was named cigar. Who knows man. It will be a pain but you need to manually check every fuse.
is there another location for fuses? 13 fuses doesnt seem like thats all the car would need even if it was that old. There must be a different fuse holder location. I would also check your grounds. Another easy test is get a volt meter and check your constant and your ground.
You can also set up your subs at 1-OHM. There are quite a few 5-channel amps that will do that, such as the Sundown Audio SAE-1100.5.
52
Also, it depends on the type of wire they installed. Copper will carry a lot for power than aluminum. How much power is your US Acoustic amp...
126
729
999
rigsboo
rigsboo
marion va
rigsboo
