Need help, bump in horn throat.
Caz
ca
ok so i got this small little bump in the mouth of my horn (the cirlcled area. i was gunna sand that down but then i noticed that both of my horn bodies have that same bump. is it designed to be there or should i sand it down perfectly smooth.
http://www.icixsound.com/vb/icixnation2.php?do=view&id=251
3rd pic down on the right side.
also becuase of some very very minor bubbles in the platic mold (so small it was hard to feelt them) i sanded it all down with 1500 grit sand paper. would it be ok to primer it up and re-paint them as long as i make sure it is absolutley smooth.
this looks like a blurr, this is what i mean
bah i sorry the camera wont focus down in there. basically is looks like a plastic blob about 2mm tall and 3mm wide.
but its odd becuase its in both horns.
Yeah, isn't that the test you are supposed to do when you wake up and notice a lump? See if on the other side as well?
//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
yeah dude like paikaih said, if its in both it must be there for a reason. check to make sure they are in the same spots. but yeah otehr than that i have no idea, what kind of horns are they?
Caz
Caz
ca
Bavarian3
BP1Fanatic
    May 14, 2026
BP1Fanatic
    May 14, 2026
